Nuki Smart Lock: Compatibility Guide.
Does the Nuki Smart Lock U.S. fit my door?
Key & Cylinder Requirements.
Compatible Cylinder Types
The Nuki Smart Lock is compatible with most single cylinder deadbolts.
Thumbturn
If you lock your door from the inside with a thumbturn, the Nuki Smart Lock is compatible.
Dimensional Requirements.
Door opens inwards:
Does your door open inwards? Then the distance from the deadbolt center to both the door frame and the handle must be more than 1.38 inches.
Door opens outwards:
Does your door open outwards? Then the distance from the deadbolt center to the door frame must be more than 1.58 inches, and the distance to the handle must be more than 1.38 inches.
The Smart Lock Pro is suitable for your door? Perfect!
