Nuki Smart Lock Pro: Compatibility Guide.
Does the Smart Lock Pro fit my door?
Key & Cylinder Requirements.
The Nuki Smart Lock Pro will be mounted over your current key on the inside of your door. You will therefore need to check your cylinder and key.
Compatible Cylinder Types
The Nuki Smart Lock Pro is compatible with most common European cylinder types.
*Yes, if the cylinder overhang is < 6 mm and you use the stick-on mounting plate.
Emergency function
With the emergency function you can unlock your door from the outside, even if a key is inserted inside. Additionally, inside and outside keys turn synchronously.
Does your cylinder not have the emergency function? We recommend the Smart Lock Ultra.
Key thickness: ≤ 4 mm
Your key must be no thicker than 4 mm to fit inside the Smart Lock Pro.
Key length: protruding ≤ 37 mm
Your key must protrude no more than 37 mm to fit inside the Smart Lock Pro.
Key orientation
Nuki is compatible with horizontal and vertical key orientation.
Dimensional Requirements.
Door opens inwards:
Door opens outwards:
The Smart Lock Pro is suitable for your door? Perfect!
