Nuki Smart Lock Ultra: Compatibility Guide.
Does the Smart Lock Ultra fit my door?
Cylinder Requirements.
Compatible Cylinder Types
The Nuki Smart Lock Ultra is compatible with euro profile cylinders.
Inside length: ≤ 68 mm
Measure from the retaining screw to the inner door plate, not including the cylinder overhang. This inner length shouldn’t exceed 68 mm.
Outside length: ≤ 55 mm
Measure from the retaining screw to the outer door plate, not including the cylinder overhang. This outer length shouldn’t exceed 55 mm.
Extensions available for outside lengths exceeding 55 mm
Dimensional Requirements.
Door opens inwards:
Door opens outwards:
The Smart Lock Ultra is suitable for your door? Perfect!
Additional notes.
