Nuki Smart Lock Ultra (Euro Profile): Compatibility Guide.
Compatible Cylinder Types
The Nuki Smart Lock Ultra is compatible with euro profile cylinders.
Inside length: ≤ 68 mm*
Measure from the retaining screw to the inner door plate, not including the cylinder overhang. This inner length shouldn’t exceed 68 mm*.
* 68 mm ≈ 2.68 in
Outside length: ≤ 55 mm*
Measure from the retaining screw to the outer door plate, not including the cylinder overhang. This outer length shouldn’t exceed 55 mm*.
* 55 mm ≈ 2.17 in
Door opens inwards:
Does your door open inwards? Then the distance from the keyhole center to both the door frame and the handle must be more than 30 mm*.
30 mm ≈ 1.18 in
Door opens outwards:
Does your door open outwards? Then the distance from the keyhole center to the door frame must be more than 40 mm*, and the distance to the handle must be more than 30 mm*.
40 mm ≈ 1.57 in | 30 mm ≈ 1.18 in
The Smart Lock Ultra (Euro Profile) is suitable for your door? Perfect!
