Bye summer, hello easy access.
Get 20% off the Home Set Pro NFC. For a limited time only.
Nuki Keypad 2 Pro.
Open the door with your fingerprint. Faster and more elegant than ever before.
€349Buy now
Make your entrance stand out with Keypad 2 Pro.
Quick opening
Open your door via fingerprint in seconds.
Elegant design
Seamless installation and high-quality stainless steel front.
No battery change necessary
Direct power connection for more user-friendly operation.
Latest technology meets unparalleled design
  • The elegant Pro version of the popular bestseller offers the same impressive features as the Keypad 2.
  • Milling and wiring required.
  • Installation by a specialist is recommended.
All benefits at a glance
Flexible access
Store up to 20 fingerprints and 200 individual entry codes.
Individual power supply
Continuous power supply or battery operation possible.
Secure mounting
Thanks to its flush mounting, the Keypad stays securely in place.
Icon of a puzzle piece being touched by a finger, symbolizing the easy and tool-free installation of Nuki products.
Perfect accessory
Compatible with Smart Lock (2.0 and higher) and Nuki Opener. Can be optimally combined with Nuki Smart Door.
We have the ideal set for your home
  • Smart Door: Designed for new houses. Integrated directly into your front door.
  • Keypad 2 Pro: Open your door in a matter of seconds with your fingerprint or an entry code.
Are you a professional craftsman and prefer to assemble the Keypad 2 Pro yourself?
Order it directly in the Nuki Shop.
€349Buy now
Compare our Keypads
Nuki KeypadNuki Keypad 2 - enter your home with pin or fingerprint
Keypad
Open doors via code
Keypad 2
Open doors via fingerprint or code
Open the door via fingerprint
Cross
Checkmark
Open the door with an entry code
Checkmark
Checkmark
Assembly
Easy DIY assembly
Easy DIY assembly
Battery life
Up to 18 months
At least 12 months
Material
Silicone cover
Plastic (PC+ABS)
€89
BUY NOW
€159
BUY NOW
