Nuki Smart Lock Go: Compatibility Guide.
Does the Smart Lock Go fit my door?
Key & Cylinder Requirements.
The Nuki Smart Lock Go will be mounted over your current key or knob on the inside of your door. You will therefore need to check your cylinder and key or knob.
Compatible Cylinder Types
The Nuki Smart Lock Go is compatible with most common European cylinder types.
Emergency function
With the emergency function you can unlock your door from the outside, even if a key is inserted inside. Additionally, inside and outside keys turn synchronously.
Does your cylinder not have the emergency function? We recommend the Smart Lock Ultra.
Compatible knob cylinder brands
Do you lock your door from the inside with a knob? We support a wide range of knob cylinder manufacturers.
Nuki is compatible with knob cylinders of the brands Abus, CES, CISA, Dom, Dormakaba, EVVA, Keso, M&C, Mauer, Nemef
Winkhaus
Yale
Key orientation
Nuki is compatible with horizontal and vertical key orientation.
Dimensional Requirements.
Door opens inwards:
Door opens outwards:
The Smart Lock Go is suitable for your door? Perfect!
