Refer a friend - limited offer.
In addition to the referral discount your friend gets Guarantee Plus for free
learn more
Nuki Smart Lock Ultra: Compatibility Guide.
Does the Smart Lock Ultra fit my door?
Cylinder Requirements.
Compatible Cylinder Types
The Nuki Smart Lock Ultra is compatible with euro profile cylinders and Swiss round cylinders.
Inside length: ≤ 68 mm
Measure from the retaining screw to the inner door plate, not including the cylinder overhang. This inner length shouldn’t exceed 68 mm.
Outside length: ≤ 55 mm
Measure from the retaining screw to the outer door plate, not including the cylinder overhang. This outer length shouldn’t exceed 55 mm.
Extensions available for outside lengths exceeding 55 mm
Dimensional Requirements.
Door opens inwards:
Door opens outwards:
Take a closer look at the installation process
The Smart Lock Ultra is suitable for your door? Perfect!
Additional notes.
