Bye summer, hello easy access.
Get 20% off the Home Set Pro NFC. For a limited time only.
Nuki Smart Lock Ultra Nordics: Compatibility Guide.
Does the Smart Lock Ultra Nordics fit my door?
Cylinder Requirements.
Compatible Cylinder Types
The Nuki Smart Lock Ultra Nordics is compatible with typical Scandinavian oval and round cylinders that have either a thumbturn or a key on the inside of the door.
Key or thumbturn
If you lock your door from the inside with a key or thumbturn, the Nuki Smart Lock Nordics is compatible.
Deadbolt
Your cylinder needs to have a deadbolt. If you lock your door with your key or knob, for example, the deadbolt moves out to secure your door.
If you operate your door only by a latch, the Nuki Smart Lock is not compatible.
Dimensional Requirements.
Door opens inwards:
Does your door open inwards? Then the distance from the deadbolt center to both the door frame and the handle must be more than 30 mm.
Door opens outwards:
Does your door open outwards? Then the distance from the deadbolt center to the door frame must be more than 40 mm, and the distance to the handle must be more than 30 mm.
The Smart Lock Ultra Nordics is suitable for your door? Perfect!
Additional notes.
